I have a small 8hp Murray riding mower. I have built a receiver hitch on the back of the mower, that I use to pull my trailers around when I mow. I have a small disc and another small cultivator that I'd like to use as well as to build a rake to pull behind this mower. I want to build a manual lift that would let me lift my implement of choice and work in the receiver. I am a blacksmith and a welder with a really nice shop that includes a cnc plasma table. So fabrication is not a problem. I'd just like some ideas on how one might accomplish this. A 3 point lift is not exactly what I am looking for. While I don't like the idea of reinventing the wheel to do this, I don't think it has to be all that complicated either. I can reconfigure my hitch to accommodate my situation.
a small tractor would not benefit with a true 3pt lift... you could make a variation of the single point lift used on a lot of older garden tractors...
Without hydraulic power you could use an electric actuator, 12 volt not too big a problem...
Plasma cutters are the BEST... :smile:KennyV
#3
lizard
The implement can have a wind up jack attached to it.......this would be the way to go......most farm implements have these and work well.
:confused2:
