ILENGINE thanks,Ithought thats where those pieces came from..
southam
looks like i need a new plate, and those pieces.The plate is scored, so is the top of piston. maybe i could polish them and replace pieces??? can I get just those??
Re: ILENGINE thanks,Ithougne uht thats where those pieces came from..
The pistons will come as an assembly with the rotating part of the pump/motor. if the center section is scored it will need to be replaced. the rule is if you can catch a fingernail in the grooves on the center section it has to be replaced along with the associated pump and most like the motor parts because damaging one usually takes out the other.
