ignition problem
trackfodder
My lawnboy model 10323 has no spark. I got a coil recently that works great until I got it home and tried to start it 2 days later. I couldn't see any spark. Removed the flywheel and finally figured out there are no breaker points Aparently CDI. What to do?
Scrubcadet10
Moderator
Staff member
The coil should have a black kill wire that hooks to it, try starting it with that unplugged, if it starts with that kill wire unplugged the wire or switch is bad and shorting to ground. if no spark with the kill wire unplugged, bad coil.
but then it sounds like you need to find out what's killing the coil.
Parts tree shows the coil Part number as Lawn-Boy 99-2911 .
