chemingthroughtheleather
What's wrong with loud arse and slow!? :laughing:
Really !!My Raptor SD only has these drawbacks next to the 16 MPH Hustler next door. It doesn't run 16 MPH. It does, however, ride more smoothly, due to a much better seat, wider tires that require less air pressure. The only other thing I don't like is the deck height adjuster sucks. Other than that, the three owners with adjacent properties with the expensive Hustlers likes mine better than theirs.
Mine came with a suspension seat, has flex forks out front and 8 PSI tire pressure. (Yes I can run lower tire pressures also)In the Z's defense, the neighbor is afraid to turn it loose. If ya got it, use it. But then, with his seat on my property, it nearly shook my eyeballs out. And that was fter all the dirtwork and sodding. Lol
Correction.Mine came with a suspension seat, has flex forks out front and 8 PSI tire pressure. (Yes I can run lower tire pressures also)
Mows my 7 acres in 2 hours.
I have a 2013 Super Z and they come with suspension seat. (Super Z and Super Z HD come with suspension seat)I wonder why the neighbors Z doesn't have a suspension seat on his? He bought it new in 13.
Do you recommend the flex forks?
