Idle speed
Toby442
What is the regular idle rpm speed for 8 hp Briggs and Stratton genorator model 197412. Type 0124-01 please help thank you so much ?
Yes Slomo for a generator setup you want be at 3750 off load to have the correct Hz whenever it is connected to electrical items but he ask for the idle speed of the engine and that old breast of a Briggs was designed to have an idle speed of 1750. The spec was found on the engine lookup of the Briggs Power Portal for that spec engine.
Technical Specifications​
Model Series1974
Displacement318
Oil Capacity48 oz (1.4 l)
Valve ConfigurationL-head
Flywheel Torque65 lb/ft (88.0 Nm)
Governor Arm Torque45 lb/in (5.0 Nm)
Carb Mount85 lb/in (9.5 Nm)
Plug Gap0.03 in (0.75 mm)
Intake Valve.005-.007 in (.13-.18 mm)
Exhaust Valve.009-.011 in (.23-.28 mm)
Idle Speed1750
Air Gap.010-.014 in (.25-.36 mm)
Flywheel Puller Part19165
Flywheel Holder Part19433
Connecting Rod Torque185 lb/in (21.0 Nm)
Sump Torque140 lb/in (16.0 Nm)
Head Torque165 lb/in (18.5 Nm)
Just don't want be idling producing power under load. The OP may have one those generators with idle down mode. I have worked on a couple that had that feature even as old as they were.
The reason for the 3750 spec as an off load spec is the governor droop under load.
Yup I read that 1750rpm on there.
