Pastor Dan
- May 26, 2025
- 1
- 3
When I was cutting the lawn the mower died. When I tried restarting with the key no sound. I took apart the machine and tested each component. I began at the battery and it is testing 12 v the. To the solenoid and it was faulty so I replaced it. Still no start so back to testing. There is a piece that shares a bolt with the solenoid. It has three wires coming out of it that goes to a black plug. The piece is aluminum and domed shape. This piece failed continuity. I also checked the circuit breaker and it is good. I have checked grounds and cleaned (with electronic connection spray) all connections. What is this piece and is it faulty? Thank you
