SanAntonioJoe
- Jun 11, 2013
- 1
- 13
OK, just lost the ider pulley on my Cub Cadet LT i1046 mower deck, purchased in 2007. The bearing seal is gone from one side, the bearings are exposed and the bolt holding it on bent and came loose. Deck is off, part number is identified, and about to order it. Have a few questions before I replace the pulley and put the deck back on.
1.The OEM part number is 756-04129B, (replaces 756-04129) and the Oregon part number is 34-204. There is only a few dollars difference in the price between the MTD OEM part and the Oregon part. Has anyone had better luck with the OEM vs. Oregon part? Is there any other brand of replacement parts that lasts longer than MTD or Oregon?
2. The deck spindles have a little noise in them, suggesting they have some wear too. How long do they normally last, in years since manufacture or hours of use, and, especially, would you go ahead and replace them now that the deck is off or is that unecessary to do so? All three spindles are available on Amazon for about $112
3. Any other suggested items to check or replace while I have the deck off the tractor? The belt is less than a year old and looks OK.
This is a home-use mower that I use to mow two acres. Thanks in advance for your advice.
Joe
Joe
