Sparty77
- Aug 10, 2022
- 1
- 4
I have a super LT 1554 and I have a good battery but it will not start if I hook the jumper pack to it it starts and runs my voltage is showing 17 and if I call for the PTO it will stall after tries to engage. Also it doesn’t even crank unless the jumper pack is hooked up but you can hear a small click from the starter and my little dash screen will kind of flicker and fade unless it is running or when I hooked a jump per pack up
