i need help diag lazer z hp no forward or reverse
grease
I have a lazer z hp zero turning mower and i have no reverse or forward. It turns on and runs i checked the hydro companents and no leaksialso checked the fuses and they are ok. Anyone run into this before any help will be greatly apreciated
grease
Thanks for the reply and the link it helped alot i was able to get it moving next time ill remember to post model # thanks again
chance123
Care to share what the problem was? Was it perhaps the 2, 5/8 bypass bolts needed to be tight?
randyb
  • / i need help diag lazer z hp no forward or reverse
I'm having same problem. What was the fix? :confused2:
