djdicetn
- Sep 3, 2012
- 2,193
I got a Toro ZTR in late June, already have 24 hr. on it, cut about 3 1/2 ac. really a joy to cut the grass, Really like the Mower, before this we were using 2 John Deer LT Mowers, a 46 in cut & a 60 in cut, I went with a Toro 3000 series with a 52 in cut, reason for that is the 60 in mower could not cut in some of the tight places, the 52 in will take the place of both of the other mowers, I am keeping the JD LT 445 mower to pull my Cyclone Rake, that I use in the Fall to pick up the Leaves from our 18 Pecans Trees, it does a nice job of removing the leaves so the pecans can be picked/harvested
I can bet you're loving that Z-Master 3000 series!!! Question....on the Turbo Force Deck, there is a feature I am curious about which is described in the Toro brochure as a "Patented Adjustable Discharge Baffle" that purportedly allows you to "quickly modify the cutting chamber to deliver a superior cut regardless of the mowing conditions". Exactly how does that feature work.....do you use it.....and is there a noticeable difference if you adjust it for extremely "wet" or "tall" grass which are the only adverse "mowing conditions" that come to mind????? I was very impressed when I looked at the Toro's that had the Turbo Force decks and of course my Gravely had their "flagship" Gravely exclusive "X-Factor" deck(that carries a lifetime warranty" and is just as impressive looking as the Turbo Force). But it doesn't have a similar "Adjustable Discharge Baffle" feature and I'm wondering what I passed up on not going with the Z-Master:0)
