I have an LX188. Its started to lose speed in forward and reverse after about 1/2 hour of mowing. It also makes a high whining noise When I press the
Hurlu
  • / I have an LX188. Its started to lose speed in forward and reverse after about 1/2 hour of mowing. It also makes a high whining noise When I press the
LX188 quits moving after it heats up, belt or pully
Could be either or both. I’d start by replacing the belt.
After 20 years the tranny is probably gone
The cheap & nasty test is to put the mower on slope, turn the engine off and give it a little push.
If it rolls easy or starts rolling & does not stop then the transmission is shot.
As an example I use a tilting trailer to pick up mowers
A good tranny will need to be pulled off the trailer
A worn one will roll easily after a slight pull
A stuffed one will start to roll the instant the trailer tips.
Some times you can stretch the life of the tranny by draining it & refilling with heavier fully synthetic oil 20w50 as JD uses 10w50 or 10w40 .
But from now on that tranny is on borrowed time.
They are rebuildable if you can get your hands on a pump & motor .
