morales_marcos
- May 11, 2011
- 1
- 2
What I did whas add a heavy duty blade cutter and i think it was too heavy. When I replaced the original trimmer i noticed it would not turn/spin with the power it used to have. When it hits the grass it stops turning as if the power is not there no more. Need help maybe something in the shaft is broken. I tried to remove the lower end and i was afraid to undo the bolt thats down in there. Any advise as to replace or repair would be greatly appreciated.
