I have a 21hp V-Twin Craftsman B&S engine - on a DYT4000, with a no-reverse issue.
BiggyJ
Ok guys/gals...
Back again with a new DYT4000 problem, and a no-reverse
issue.
If you remember my other post, I had a squealing issue
and the mower would not go forward or backwards unless
you pulled up on clutch/break. I ended up fixing THAT
issue with new belts. (go figure)
Problem:
BUT... after putting the new belts on, I have no reverse.
Worked fine before I replaced the belts.
Reverse worked fine before I replaced the belts.
(as long as you pulled up on the clutch/break pedal)
I tried adjusting the shift linkage. Made no difference
even when I adjusted it all the way from end to end.
What else can I check guys?
Thank you,
Johnny
Thanks Your mom...
I don't even understand what all that means but I will try to digest it :)
Thank you kindly,
Johnny :)
PS - I see you just signed up. Probably just to make this crazy post! Go
mess with someone else with this "bucket of steam", left handed wrench",
"metal stretcher" nonsense!
How about a model number from under the seat? We’re not next to you sliding paper around and need to see the which drive system you are dealing with.
Dang... very sorry Rivets, I should have posted it :)
Model # 917.274040
Thank you very much,
Johnny
Model # 917.274040
Johnny
