I have a 21hp V-Twin Craftsman B&S engine - on a DYT4000, with a no-reverse issue.
BiggyJ
  • / I have a 21hp V-Twin Craftsman B&S engine - on a DYT4000, with a no-reverse issue.
Ok guys/gals...
Back again with a new DYT4000 problem, and a no-reverse
issue.
If you remember my other post, I had a squealing issue
and the mower would not go forward or backwards unless
you pulled up on clutch/break. I ended up fixing THAT
issue with new belts. (go figure)
Problem:
BUT... after putting the new belts on, I have no reverse.
Worked fine before I replaced the belts.
Reverse worked fine before I replaced the belts.
(as long as you pulled up on the clutch/break pedal)
I tried adjusting the shift linkage. Made no difference
even when I adjusted it all the way from end to end.
What else can I check guys?
Thank you,
Johnny
BiggyJ
Thanks Your mom...
I don't even understand what all that means but I will try to digest it :)
Thank you kindly,
Johnny :)
PS - I see you just signed up. Probably just to make this crazy post! Go
mess with someone else with this "bucket of steam", left handed wrench",
"metal stretcher" nonsense!
BiggyJ
Hm...
How about a model number from under the seat? We’re not next to you sliding paper around and need to see the which drive system you are dealing with.
BiggyJ
Dang... very sorry Rivets, I should have posted it :)
Model # 917.274040
Thank you very much,
Johnny
BiggyJ
Model # 917.274040
Johnny
