Mower manic
- Aug 1, 2011
- 3
- 228
I speculate that most of your problem lies in your grass. I am arriving at this assessment because my grass does not stick to the under side of the deck, (we have very different types of grass). I know from reading your past posts that you do not cut wet grass and your grass is quite fine, at least compared to southern grasses...So I'm of the assumption that because your grass is so fine, it clings to the under side of the mower. The moisture that resides in the grass itself facilitates this adhesion...so it accumulates.
I suspect the way to deal with this problem is to use the pressure washer more often and avoid the scraping part of your cleaning. Try pressure washing every 10-15 hours and perhaps you won't have to scrape at all. I would also suggest fabricating a low pressure, 180* (or less degree angle) device to wash build up before it gets a chance to dry and harden, using the pressure available from your well or public/municipal connection
Such is the cards you are dealt my friend. You can deal with it more often with less work, or 2-3 times a year with more work.
As far as coating your deck goes; I don't think any oil will get you to where you want to be. Nothing short of a very expensive teflon coating will create the surface you are looking for. If you could get it very clean and there is paint on the under side yo may want to try a silicone product, but only if you still have a comprehensive painted surface.
