Devon Rider
- Dec 7, 2019
- 1
- 5
Can anyone help?
I have a 2003 HF2216 H lawn tractor (made in France) which has been losing traction. I thought the hydrostatic transmission must need topping up. The Operator's Manual provides no information on maintenance of the transmission. All it says is the rear axle "is a sealed single unit which does not require maintenance. It is permanently lubricated and this lubricant does not need changing or topping up."
However the tractor has almost stopped going so I removed the plastic grass shoot to get a better view of the top of the transmission. I discovered an empty plastic header tank on top of the transmission unit. I can't find any info on what to put in it. I have found some references to other Honda tractor models using SAE 10W30 engine oil with API classifications of SE, CC, or CD, but NOT to use Honda Hydrostatic fluid. In any case I can't find a source here in the UK for Honda Hydrostatic fluid.
Any advice would be gratefully received.
