I have a 2002 MTD Yard Machine 42" with a Briggs & Stratton 17 HP OHV engine, it is an automatic. runs great, but it doesnt stop. "break works fine if mower is not running" the brake pedal and gas pedal are both on the same side. if i let off the gas pedal while in gear, the mower keeps moving. nothing i do seems to disengage the transmission either, so i have to pull it to neutral.
