i have a bad hydro tranny with the pedal drive and i have a parts mower with the hand lever drive
are these the same trannys that will just swap out or does the hand drive hydro have different connecting points for things?
i know mtd single speeds are all the same no matter the model numbers differ and john deeres swap the brakes to the left side to make them different then everything else, but how universally interchangeable are the hydro trannys when one is a hand drive version and the other is a pedal drive version as long as you stick to the same brand of mower?
