Repairs hydro oil
patriotdoc
I have a 721D & need to add some trans fluid what should i use anything besides grasshopper oil?
While there are replacement oils out there for your 'Hopper, the small amount used to maintain them is not worth mixing the oils. Bite the bullet and just buy a quart. If you have a good tight system, the quart should last you a long time. :smile:
I go with what Sammy said.Why take a chance on mixing diff. fluids.It's a little pricey but piece of mind is priceless...russ
