- Feb 19, 2020
- 116
- 12,596
You got to understand you are going from no compression load with the plug out to a compression load with the plug in. This changes to whole dramatics of the rotating engine components. I have even seen recoil starter to jam because compression load. If you have worn crankshaft bearings the crankshaft can shift position under compression load.
Since this is a 21" walk behind install the plug (leave plug wire off to prevent accidental starting) and try rotating the engine with the engine brake off with the cutting blade.
