Repairs Hydro Gear pump BDP-10A 414
southam
Pump was leaking. Took apart and found small pieces of metal. Looks like 4-5 sets of 1/8" flat discs and 1/4" oblong parts. looked in the pump but didn't see where they could come from. Thinking they came from drive gear. The mower seemed to run fine. ANY THOUGHTS ON WHERE THESE PARTS CAME FROM???
If the pistons came out of the base piece when you disassembled, They could possibly go above the springs inside the pistons
