tew45
I have a RZT 50 Troy bilt and after about 30 minutes of use the right hydro just quits and growls at me. I have to let it rest 30 minutes then take it to the house after it starts working again. I have heard from many people that is a common fault with the MTD made mowers. I have checked for loose components, dirt build up, and broken fans. My wife uses it and keeps it squeaky clean. It has 236 hours on it. I have heard others say that you are lucky if you get much more than 200 hours on a hydro. That makes the machine very expensive since the replacement cost is around $800.00 to $1,000 like buying a new machine every 200 hours. Has anyone found a reasonable repair for these parts?
