Hi all,
I have an 88-89 John Deere Hydro 185 with 38" deck and snow thrower attachment. This winter I replaced the belt for the snow thrower and worked great. Started it several times and tested the thrower. Now as soon as it snows the tractor will not start. It has fuel, spark and air. It turns over but will not fire. If I move the throttle from choke to slow it sounds like it wants to fire but still wont. Have what seems to be good compression. Ran fine then stuck shoveling Any ideas?
Thank you
Jon
Thank you
Jon
