Hydraulic pump bypass valve hustler 3400 zt mower
ohio farmer
Hello, I have a hustler 3400 zt mower, and I believe the bypass valve is stuck partly open, when running the wheel only has part of the power compared with the other side, and the bypass valve won't turn either direction any suggestions?
thanks mechanic mark, that worked its loose, but it still is lacking power compared to the other pump.
