Hydraulic fluid change Gravely 260z
Boxkicker3rd
Does any of you know how to change hydraulic fluid on a gravely 260z. Manual says to drain reservoir but this only gives about a quart and system should hold about 5 quarts. I've tried moving steering arms while engine running and not running but no change. Thanks for any advice.
Boxkicker3rd
I already did exactly that. Even with filter change and draining the reservoir it still only gives maybe a quart and a half. Some one said to disconnect hoses, but I don't want to do that as I can see leaks starting. Anyway, thanks for your research.
