Shifty2002
- May 6, 2025
- 1
- 2
Original problem - key switch did not engage starter. Recently replaced my starter solenoid, wasn't the problem, eliminated down to starter relay under control panel. Mow starts fine now.
Went out to mow and when I brought the arms in to drive the engine died. Ended up linking the two arm kill wires together and the seat safety switch to eliminate Kill Relay issues. Now mower starts, no more arm or seat kill. When I go to turn the PTO on, mower dies. Blades can be turned by hand. PTO starts to engage before motor dies.
Found a 6 pin connector coming out of the motor with red (hard connector to motor), green and black (push connectors), all located in a row of top pins on connector housing. Red wire has a jumper that comes out of the top pin connection and makes a single pin below. Notice the jumper pin has corroded free from connector housing and on tractor side the corresponding blue (maybe purple blue?) wire was also out of the connector. turned these into male/female connector, reinstalled
Mower still dies when I try and turn on the PTO
