Hustler Raptor SD 42” Mulch Kit??
Clivehamilton77
Hey all!
New here so forgive me as I’ve tried using the search function to find my answer to no avail. I currently have a Hustler Raptor SD 42” (938142) and want to get a mulch kit but am having trouble finding one. All the mulch kits I see don’t have my model number listed or it just says the Hustler 42”. Does anyone know where I can find a mulch kit for a Raptor SD 42”? Or if the normal 42” kit will work? By the way it is a 2018.
Any help is appreciated. Thank you.
Clive
mechanic mark
https://www.hustlerturf.com/file/dac6bca6d2261621252a3ca65eba759dde58736e.pdf
part # 123163 is 42" mulch kit for your Hustler Raptor SD
https://www.google.com/search?q=HUS...ome..69i57.38626j0j4&sourceid=chrome&ie=UTF-8
Search for best deal.
https://www.hustlerturf.com/support/manuals
To be honest Clive I'm not sure. SD decks should be of thicker gauge steel & heavier duty hardware & attaching parts, quality matters & I'm sure Hustler parts are of the finest materials. Always use Hustler OEM parts, belts, pulleys, etc.
Clivehamilton77
Thank you @mechanic mark. Is there any difference you know of between the deck of the2018 42” Raptor SD and the 2018 regular 42” Raptor non-SD?
Thanks again for the links. I’ll be purchasing.
