JeffArnold
- Sep 12, 2021
- Threads
- 1
- 1
Figured out a way to keep my drive belt from jumping off on my hustler raptor. I noticed the black plastic fans above my transmissions were bent upward towards the drive belt, dealer said solution to that was to replace, that means you’re in for a lot of labor and he said that’s all you could do, I beg to differ, I took my heat gun and heated each plastic blade on both fans one blade at a time and then I would hold downward on the blade with a cool wet rag until blade cooled in place, it worked, now the blades are more downward like they should be and no longer upward pushing my belt off
