Hustler Raptor 42 or Gravely ZT 42?
sjdoucet13
Ok, so I keep going back and forth on a decision. Local dealer here recommends two mowers...and I see pros and cons of each. Also will be getting the mulching kit on the mower. ($200 installed) My budget is low $3000's. Any help?
Yard to mow is a 1 acre lot with my house and pool and obsticals. Roughly half acre to cut. I cut currently with a 46" Troy Bilt Horse which is in dire need of replacing. Takes about 2.5 hours to cut.
Hustler Raptor 42 $2899
Pros:
fab thicker deck 11 gauge
kawasaki engine
Bigger fuel capacity
Cons:
slower blade speed than gravely
2 point mount on deck
Was told there's a grass "trap" on top of deck which is a problem area on this mower
Gravely ZT 42 $2999
Pros:
Faster blade speed than hustler
4 point mount on deck
Foot lever to raise deck
Cons:
Kholer engine (I hear kawasaki is better)
Stamped deck 12gauge
-Scott.
Shughes717
Pros:
kawasaki engine
Cons:
Gravely ZT 42 $2999
Pros:
Cons:
-Scott.
Both brands have a great reputation, and would be well suited for your needs. Just go with the one you like best. Don't over think it.
MRCo.
I've sold many Raptors and never heard of a deck grass trap issue...weird. All my customers love them.
I guess you know which I recommend! :)
With 1/2 an acre to mow, toss a coin.
Go for which ever has the tigetest turning circle and is the most manoeuvrable.
Check you can get a clear view of the left side ( close mowing side ) of the deck and blades that are closest to the left side ( less trim cutting )
sjdoucet13
Well, I went back and looked again. I ended up getting the gravely zt 42. I felt it was more comfortable on the backside... the seat was softer.....lol. I think I ended up with a good machine. I'll post pics soon.
Scott.
Shughes717
Scott.
Congratulations, let us know your initial thoughts after mowing with it a few times.
