That has been the only real issue I ran into so far. I had to grind the anchor off the Cub and weld it on the Hustler. I have a longer throttle cable on the way. The throttle and choke cable route on the same side for the FR and route from both sides of the engine on the FH. Hopefully not a big deal.Probablyth
You will need to work out an anchor for the PTO and the blades might end up being a little faster( pulley bigger ) or slower ( pulley smaller )
The diameter of the clutch on the FH is smaller but the pulleys are the same diameter. If the engine does fine but the smaller clutch becomes a problem I may have a bushing made to accept the 1.5" clutch off the FR. Fingers crossed.
