clemsontigerman
- Mar 4, 2017
- 2
...The fuse in question are not the two mounted outside the right side fuel tank, but the one underneath the control panel that is housed in a small rubber case; the fuse blows when I go to start the machine. I have replaced ignition switch, PTO switch and engine will turn over when I bypass starter solenoid. Any help would be greatly appreciated...
