Husqvarna
dougs55
I have a 2011 Husqvarna LGT 2554 the charging system does not work, i need to know how to check it and or repair it .
thanks Doug Smith
2011 charging system should be covered under warranty, so the best thing to do would to take it to your dealer and let him fix it.
KennyV
Check the voltage On the battery before the engine is started and again after the engine is running... :smile:KennyV
