Always Learning
While I was mowing my lawn on a flat not-bumpy surface with my ZT254, the blades stopped turning. The blade switch was still up. The mower continued running as normal but the blades would not engage.
I traced the wiring to the clutch and there's no sign of wear. The wiring connector for the blade clutch behind the starter does not have power to the clutch from the switch when activated. It's an open circuit regardless of switch position. Applying 12v from the battery directly to the wiring to the clutch I hear the clutch engaging so I think it's good.
I swapped out the blade switch with a new one since it was easy but no change.
I know the seat switch will keep the motor from running but, in this case, the mower is running fine. The blades just won't engage. Any thoughts?
It's been a good mower but troubleshooting safety systems and issues like this is difficult. Straight wiring w/o safety circuits would be preferred. Thanks
