Husqvarna Z254F Stripping Mandrel Pulley
Expensive little mistakes caused by me not laying out parts in the order they came off so they can go back in the same order
I have seen brand new mowers fitted with a mix of genuine & aftermarket spindles so not sure if the factory ran out of the usual part or the dealer replaced parts damaged in transit with generic parts but the one that sticks out was a ZTR that had 3 different spindles 2 with unified threads and one metric and all of them different sizes .
Now Bert don't you have a photographic memory?
It helps a lot to be able to move things around in your mind as I do. I can look at an object and mentality turn it and flip it around in my mind. Sure helps when you torn down for the first time a Kawasaki 3010 UTV and then 3 months pull the parts out of a box and reassembly it. Just got nearly done with it today and it came in May 9th. Now I got to get to front CV axles and the Honda rear differential from April 13th. The differential is in four 5 gallon buckets and it was the first tore one them down too.
Too bad I can't move the actual parts around with my mind.
