ricochet1026
- Jul 9, 2019
- 1
- 4
Newbie here. I purchased a used 2016, Husqvarna Z246, 105 hrs, B&S 23HP Ready Start Endurance motor from an estate last week. Very clean with fender abuse from someone trying to learn how to drive I guess.
While cutting under full throttle and deck clutch engaged, the motor runs great. When I disengage the clutch the engine/governor surges up then down regardless of the throttle setting.
I have put in new gas along with some SeaFoam cleaner, full tune up (plugs, air filter, fuel filter, oil change) and checked the gas cap. I have watched numerous Youtube videos on how to set the governor on a twin cylinder Briggs figuring maybe previous owner has done something. Just wanted to check to see if it was in proper position. Not sure if it was totally as I was following procedure. Throttle wide open, loosen clamp, turn shaft to the right and lock down. After that, when I started the engine, it will only run WIDE open. Figured I did it wrong and set it the other way and same result. Both times I shut it down quickly.
Any help or suggestions to get this machine running properly would be greatly appreciated. Thanks
