Husqvarna ythk1542xp clutch won't engage
chrash
I changed my belt and about half an hour into mowing and the blades stopped. The clutch isn't engaging and the connector shows 14.5v. Bad clutch?
If it has the triangle shape with the three nuts with springs above them. May try adjusting the air gap to .012-.016 and see what happens. On adjustable style there is a slot next to the adjustment stud to insert a feeler gauge between the two rotating disc.
chrash
I appreciate your response, but no such luck. Got the clutch out and it fell apart so I figure that's it. Got I've ordered and I'll let you know if it works.
