Husqvarna YTH 2454 blade belt needed
Alweeja
Best belt? Place to buy? .....Is it a difficult job?
Thanks-
Please give us the model and serial numbers from under the seat.
Alweeja
Serial # is 032707B001810
Is YTH2454 the model #?
Alweeja
Product # is 287581
Belt number 587686701. I always recommend purchasing from your local repair shop. Take your model and serial numbers to them, have them double check the part number and get it for you. You might pay a bit more, but if it would be wrong you can take it back. Also gives you a place to get help if you need it in the future. Replacing the belt is not hard, remove deck, install belt, reinstall deck. Less than an hour. I recommend removing the deck now and check the blades and pulleys. You may need to sharpen or replace the blades and can get the deck a good cleaning plus check over before reinstalling.
Alweeja
Thanks Very much for the part # and the Usefull advice and suggestions. (y)
