Husqvarna YTH 2348 John Deere LA110
Bob Vannevel
Wife was mowing and the tractor shut off. Blown fuse. Replaced and it
started ok. Engaged the PTO and blown fuse again. Checked the schematic
and discovered there is a diode across the clutch terminals. Un able to locate
the diode so I by passed everything and the clutch will not pick up. Ohmeter
shows dead short across the clutch solenoid . My gut tells me the clutch
is burned up. Could this be the result of an overload? The center blade of the
mower was very difficult to turn due to a build up of grass . Is there a source
for used parts such as the clutch.
Also while I'm asking we have a JOHN Deere LA110 tractor with the transaxle
shot. Locks up and burned up the drive pully. Tractor is in good condition except
for that. Also would like a used transaxle. From what I see a transaxle from any
other model tractor would work as long as it has the pedals for foreward and
reverse. Sorry tfor the long post. Thanks for any help.
