GregBuchan
- Jun 2, 2023
- 1
- 5
I was maintaining my 24V48 and found an oil leak on the floor. Examining the hydrostatic transmission, I found the left axle seal out of its seat and grease was all around the inside of the tire rim and on the inside of the wheel. After removing the tire, I noticed a little whiteish oil as it dropped out where the axle enters the housing. The axel felt loose and it seemed to have pushed back in about a 1/2”. I pushed the seal back into the slot and it wouldn’t come out again. So I reinstalled the tire but cannot find a fitting to grease.
when I restarted it to pull it back in the shed, it would not engage the transmission. I checked the engage/disengage pin and it was engaged, I could hear the sound of it running when depressing the forward control and again when trying the reverse control but no movement whatsoever.
1. How do I add grease to that axle, quite a bit came out, at least 1/4 cup was sprayed around the tire side.
2. does the transmission need to be purged or could that axle cause this it it wasn’t pushed back in correctly?
3. Any insight is greatly appreciated.
Thanks!
Thanks!
