Husqvarna YT48XLS year 2013 no start, totally dead
rwbaylady
  • / Husqvarna YT48XLS year 2013 no start, totally dead
Took my mower out of storage about a month ago, ran maybe 30 minutes and stopped, just like I shut it off, tried to restart, nothing, no click, gauge and hour meter didn't respond when key turned, left it, went back an hour later it started, put it away, took it out to mow this week, ran for about 45 minutes and stopped again, towed into garage, tried again, nothing, came back next morning, it started once but stalled and have no response since, replaced the starter solenoid, no help, if I jump across the solenoid terminals, starter turns engine over fine but no start, Went to the dealer he gave me a ignition switch, mower switch, and main fuse to try. None of it helped . have taken apart all visible wire connectors , inspected and cleaned all wiring connectors, inspected all the visible wiring, no sign of chafing or rodent chewing. Looked up how to bypass the seat safety switch on you tube, that didn't help. When the key is turned on nothing happens, no starter click, the gauges do not respond, hour meter doesn't come on. Any ideas
Otis3
I just had the same problem. Ran died then nothing. Jump across solenoid cranks. Fuse was corroded and blown. Cleaned out connection and new fuse and it ran.
If you have a VOM, try this procedure and tell us what you found.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position q(you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
