any ratchet , or gear wrench you would recommend?normal right hand thread
so undone counterclockwise
Leave it there & get a sump pump
Try carefully heating one side of the boss with a propane torch. Then quench with cold water. Apply some penetrant spray for a few days. You could drill and tap it and install a smaller plug.. A sump pump is the best idea.KOHLER 7000 SERIES 22 HP ENGINE...
HAVE THE SQUARE HEAD PIPE PLUG DRAIN PLUG CAN'T GET IT TO BREAK LOOSE.
IS IT CLOCKWISE OR COUNTER CLOCKWISE???
