Hey I have purchased a Husqvarna yth22v46 with a 22 hp intek B&S from a lady a who let it sit out for a year or two. I got it for a good deal, and am trying to get it going!
So far I have changed the oil, changed the spark plugs, replaced the starter, new fuel, recharged battery, cleaned and adjusted the magnetos. The fuel pump seems to be spitting out enough fuel, although i don't have much to compare it with. I believe i did a good job cleaning the carb. I'm not sure if the throttle and governor linkage was messed with before i bought it as when i move the throttle there is barely any movement. am i missing a spring?
This engine is turning over but it is not starting. Im hearing a Thump, thump, thump noise coming from the air intake area every now and again. Ive tried spraying it with a little starter fluid. All I'm getting is a bit of white smoke.
not sure where to go from here? I think its a fuel issue. any tips and suggestions would be very helpful. Thanks
not sure how to turn these pictures the right side up, sorry
