If you have a bent push rod , there's a reason , you need to pull the head and look at the piston.
B Bertrrr Well-Known Member Joined Mar 11, 2021 Threads 5 Messages 581 Sep 29, 2024 / Husqvarna will crank but won't Start. #21 If you have a bent push rod , there's a reason , you need to pull the head and look at the piston.
S SeniorCitizen Lawn Addict Joined Aug 28, 2010 Threads 143 Messages 2,302 Sep 30, 2024 / Husqvarna will crank but won't Start. #22 Timing is close enough to run if your thumb is blown from the spark plug hole at the exact time we see a spark when the plug or wire is grounded .If it passes that test there's no need to pull the fly wheel .
B Bertrrr Well-Known Member Joined Mar 11, 2021 Threads 5 Messages 581 Oct 1, 2024 / Husqvarna will crank but won't Start. #23 If the flywheel key is only slightly sheared , it aint starting
Craftsman Garage Well-Known Member Joined May 2, 2021 Threads 38 Messages 495 Oct 1, 2024 / Husqvarna will crank but won't Start. #24 Just replace it
