Silver Wolf
- Apr 29, 2022
- Threads
- 0
- 3
You should order your trans-axle direct from the manufacture. It probably a Hydro Gear 217-728-2581 or a Tuff Torq 866-572-3441.. Get the Model# and S/N off the transaxle and give it to them. I used to work on the hydrostaic transmissions on mowers like wheel horse when they were well build and repairable. They were actually driven by a driveshaft of a horizontal engine.
If you want the trans-axle repaired, you should take just that to a hydraulic repair shop that has lapping capabilities and have the lawnmower shop install it. Most of them fail from contamination in the oil, running dry from a oil leak as well as running to hot. . It is a shame the mower manufactures would not spend a few extra dollars to have a drain plug in the trans-axle so the oil may be changed, just like the engine.. It could run for ever, but it's design for a certain life. It's the manufactures of the mowers fault so that you will buy a new one. When you get the bill, you will wish that you did buy a new one. If you are having it repaired, you could have it drill and tapped for a SAE plug so that you may change the oil.
It does't matter what manufacturer is of the mower, they all use the same trans-axles. Commercial mowers use a industrial hydro-static transmission and are repairable. Good luck
