So what causes the hydraulic pumps to turn ?
Hydro DRIVE belts cop a beating from debris thrown up by the deck.
They often jump off & sit between the fan & the pulley so they look & fell like they are properly positioned.
No one ever bothers to lubricate the tension arm pivot so it freezes and allows the belt to slip.
Even fewer people bother to clean the exterior of the hydros so they overheat & cook the oil then cut errosion paths so the oil flows out the sides of the valve plate rather than flowing through the pistons.
