Husqvarna RZ4623 - Fuel Tank Air Vent
nevils
When replacing the fuel tank vent - is it just pulled out and the replacement pressed down in its place?
Or, is there a nut or clip inside that has to be, somehow, accessed?
Thanks!
Popped out, install new sealing grommet and then press the vent back into the grommet. Put a small amount of lube on the part before pressing to make installation easier. I normally use dielectric grease.
nevils
Cool, thanks! I have CRC dielectric grease, so, one less thing to search and order. :)
