Husqvarna pproblems when engaging blades
Razormaxx
My Husqvarna mower tries to shut off when I engage blades but will continue running if I instantly push the gas pedal all the way down. I can still mow but if I let off the gas any, it dies unless I'm in reverse. It runs fine in reverse, just dies when I switch key to forward position.Any advice would be greatly appreciated.
Any particular model ?
All of the Husqvarna lawn mowers I have fixed had a governed engine with a throttle lever and other controls depending upon the type of transmission.
Model number would be nice to have to help diagnose this issue. I suspect the problem is in the reverse mow safety system.
