Husqvarna mower with Briggs and Stratton engine
Leever2000
Update - got the carburetor straightened out and the mower starts up. Only problem is it runs for about 5 to 10 minutes, noticed 1 thing the primer bulb has a hole in it, is this normal?
BlazNT
No replace it.
Leever2000
I confirmed the primer bulb is supposed to have a hole in it. So I am back to the fact the mower still only runs for a limited amount of time. Is there a way to test the coil, the mower runs strong for a limited amount of time and then just stops. I assume that the carburetor is clear and doing what it is suppose to do. I am thinking the coil gets hot and the spark gets weak or non-existant or at the very best weak.
BlazNT
What is the limited amount of time?
Leever2000
15 to 20 minutes of cutting grass.
dewguy1999
Is it possible that the gas tank is not venting properly (usually through the cap) and creating a vacuum and starving the engine of gas?
Leever2000
Had not thought of that, is there a way to check that other than taking the cap off and trying to start? I'll check later today and report.
BlazNT
Loosen the cap and mow. or whem it starts to die loosen cap and see if it fixes it
Leever2000
Loosening the gas cap had the same result, except now it starts and will only continue to run if I continue to push the primer.
BlazNT
Check your fuel lines for dirt or kinks. Sounds like a kinked or clogged line. Also re check needle valve and see if its moving when the float goes down.
