Husqvarna LTH24V48
Old Yellow
I have the LTH24V48, I ran out of gas while cutting grass as I usually do not let a lot of gas sit in my tank. I went to start the mower after a little bit and it would not start back up. I checked to see if I had spark which after some maintenance I got both spark plugs firing, replaced the fuel pump and it still won’t kick on. If I crank it a few times it will sound like it wants to turn on then shuts back down. It actually seems like the carburetor is not getting gas. Doesn’t make sense to me. Please help thank you
Remove the solenoid from the bottom of the carb & check that the pin retracts fully when the key is turned on.
If it has only one wire then it grounds through the body & needs to be grounded.
While you are there, remove the float bowl checking for water ( would have come out when the solenoid was removed ).
Without the float bowl on cranks the engine a few times to check the flow INSIDE the carb.
Let us know what you find
Old Yellow
I will check this out today and let all know the results. Thank you ??
