Husqvarna LO21H48F part?
MTGunner
Have an older model Husqvarna 2148, model LO21H48F, lawn tractor that I cannot find a part for. I am probably searching for the holy grail of mower deck lift link Husqvarna part number 532175470. This is the left hand side lift link and bolt assembly. Broke mine this AM. BTW, cost me a knuckle hell of a knuckle cut getting the broken side removed. All searches state this link is unavailable. Can anyone help. Does anyone have an older mower that I could purchase this link from them? Help! MTG
platefire
I looked, turned up nothing. Double check and make sure all your numbers are correct:)
MTGunner
Yes, part number is not correct. I made one from a 3/8” rod this afternoon. Not sure it will work. Actually steel rod is a 1/32”smaller than original. But, never know. I would like an original and the Husqvarna part number is 532175370. This is the LH mower deck lift link. In my original post I wrongly stated 532175470. This is incorrect.
532175370 LH mower deck link assembly. I have the nut but really damaged. Tom
hlw49
Post the 11 didget model no. can't get that model to come up
MTGunner
This is a 2004 Husqvarna YTH2148B or F.
I researched the part online to find it unavailable. Again the part number 532175370. It is the 2148 three blade model. Also try LO21H48.
MTGunner
I called Jacks. They do not have this part. I went on eBay. It lists many links but not specifically for my old mower. I’m at a loss. Perhaps my homemade one will work. Will keep this forum advised, MTG
platefire
Yes, it's part #11 on this Link. No Longer available
Just looking at the small picture, looks like it would be pretty easy to fabricate in a Metal/Welding/Fabrication shop if you took the old one by for them to go by
